Dear Sir!
I had 30 days left of my warrenty. Otherwise I would have been confronted with a bill half the size of product from new it eslf.
So thank you for your brilliant advice - that is goíng to the place where I bought it.
It i presently placed in our bath /shoer room - do you know if is moist sensitivr?
Thank you in advance for brilliant advice.
Kind regards
Christian
