Latest post 01-29-2009 6:56 AM by jens m. 19 replies.
Page 1 of 1 (20 items)
  • 01-27-2009 3:42 PM
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    MX5500 Speaker Replacement
    Recently I needed to replace the speakers on an MX5500. As I could not get any original ones, I modified some from Maplin's. Last night I did another, this time I took some photos of my handywork. Any comments are greatly appreciated.
    Well this first picture shows the original speaker with the dreaded foam rot. Also the coils had gone on both speakers.
    CraigSmile
  • 01-27-2009 3:55 PM In reply to
    • Craig
    • Posts 4,855
    Re: MX5500 Speaker Replacement
    After spending most of a Weekend searching for suitable replacements I ended up with these from Maplin's.
    30 Watt Shielded Speaker
    This shows the size difference to the original.
    Original and new speakers.
    CraigSmile
  • 01-27-2009 4:00 PM In reply to
    • Craig
    • Posts 4,855
    First step to modifying the speaker is to remove all of the steel frame, right up to the edge of the foam. This was done VERY carefully using a Dremel Multi tool.
    1st speaker after been cut down.
    Finished pair
    CraigSmile
  • 01-27-2009 4:10 PM In reply to
    • Craig
    • Posts 4,855
    Next I removed the old speakers from the TV. Then removed the two white horn things(not sure what they are calledLaughing). Looking at the horns, there are two marks at the 3 and 9 o'clock positions at 12 and 6 there are seams from where they are constucted. At these 4 positions I cut a slit into the horn about 1" long. This allows the new spekers to fit into the horns. On the first MX I did, I did not bother fitting the horns back. This time I worked out how to get them back into place.
    This shows the mark at the 3 o'clock position (Right hand side horn)
    At this point I soldered the wires from the original speakers on to the new ones.
    Speaker fitted into the horn
    Note how the wire is fed through the slit I have made in the horn.
    CraigSmile
  • 01-27-2009 4:19 PM In reply to
    Craig:
    Those would be the log-line tubes Laughing
    Thanks for sharing this - I have foam rot in one of my MX6000 drivers and I suppose I'll have to do something about it soon, although there are no audible problems so far. I presume these are exactly the same as in MX5500, and not available new either?
    -mika
  • 01-27-2009 4:25 PM In reply to
    • Craig
    • Posts 4,855
    Thanks Mika, I knew someone would know the answer.LaughingLaughing
    CraigSmile
  • 01-27-2009 5:47 PM In reply to
    • Craig
    • Posts 4,855
    Next it was time to take a saw to the MX.Surprise As the new speakers even after been cut down are bigger than the originals, I had to make the holes where they fit a bit bigger. As you can see I cut some from the bottom and some from the outside edge.
    Speaker hole after been cut out
    For this job I used a one handed hacksaw. Tried using the dremel again but the plastic melts and jams the cutting wheel.
    CraigSmile
  • 01-27-2009 5:54 PM In reply to
    • Craig
    • Posts 4,855
    So now I can fit the Log Line tube (Thanks MikaLaughing) and speaker back into place.
    Putting the speaker back into place.
    Note, that at this point, the speaker and tube will not fit fully back into place. They need to be GENTLY tapped into place. For this I used an 8mm drift. Slowly I worked my way around the speaker until it went into place where I wanted it. If anyone can think of a better way of doing this step I would be glad to hear it. One slip at this point and I could have put a hole stright through the foam suround.SadGlad to say that did not happen.
    CraigSmile
  • 01-27-2009 5:59 PM In reply to
    • Craig
    • Posts 4,855
    Once the speaker was in place it was a tight fit, and would probably stay there without anything else to secure it. As I wanted to make 100% sure it did not move, I very carefully drilled two small holes in the edge of the speaker. Going straight through and into the black plastic behind. Then I secured it with a couple of self tapping screws.
    Speaker screwed in place 1
    Speaker screwed in place 2
    CraigSmile
  • 01-27-2009 6:05 PM In reply to
    • Craig
    • Posts 4,855
    Time for a quick test while I had a well deserved fig and a coffee. Everything sounding great, so I refitted the fret. Once this was in place you could not tell the difference.
    Left side speaker
    Right side speaker
    Job done, and another piece of B&O rescued. Total cost £9.98, and a few hours of my time.Yes -  thumbs up
    As I said at the start of this thread, any commnents are welcome and appreciated.
    CraigSmile
  • 01-27-2009 6:20 PM In reply to
    Really interesting Craig - great to see another piece of B&O saved from the skip. Hopefully others can learn from this and more MXs can be saved.
    BTW - on a similar tip - Tim J is fixing up the BM6000 Quad I bought from you, and it should be back with me in a few weeks. That's one rare piece saved from the bin if ever there was one :)
  • 01-27-2009 7:11 PM In reply to
    • Jandyt
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Well done Craig, and thanks for taking the time and effort to share this with us.
    I'll be glad when we can post photo's straight into a thread. Fingers crossed, Keith will have it sorted shortly.
    Poor me, never win owt!
  • 01-28-2009 4:35 AM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    Craig, out of curiosity, what are the outside dimensions & spec's of the original drivers?
    Chris.
  • 01-28-2009 4:44 AM In reply to
    Medogsfat:
    I was just about to ask the same so I could order new foams withouth having the tv disassembled for weeks (or do it twice). I like your approach, Craig, but I was kind of put off by the hacksaw part Laughing
    The MX5500 and MX6000 (mine) have the same drivers, I suppose?
    -mika
  • 01-28-2009 6:48 AM In reply to
    • majand
    • Not Ranked
    • Joined on 02-26-2008
    • Helsinki
    • Posts 72
    • Gold Member
    A great thread. Thanks Graig!
    Reminds me to check my MX5500 speakers also. Somehow diregarded them as foam rot suspects. Then maybe ordering the foams together with the ones to my Beovox C75:s.
    Pekka
  • 01-28-2009 12:08 PM In reply to
    • Craig
    • Posts 4,855
    Medogsfat:
    Chris.
    Chris, the original Drivers were 10 Watt and measure 8CM across. If you want an old one as a pattern, I will pop one in the post for you.
    CraigSmile
  • 01-28-2009 1:50 PM In reply to
    • Medogsfat
    • Posts 4,045
    Tut tut Craig - I think you know what I'm going to say now don't you?Whistle
    You should have asked me first (you normally doLaughing) - I have 4 of THESE doing nothing and they measure exactly 8cms in diameter.
    Chris.
  • 01-28-2009 2:09 PM In reply to
    • Craig
    • Posts 4,855
    Chris, the speaker in your link would fit I think. Although, you might have a strange coloured picture. They need to be shielded.
    CraigSmile
  • 01-28-2009 2:33 PM In reply to
    • Medogsfat
    • Posts 4,045
    Good pointWhistle
  • 01-29-2009 6:56 AM In reply to
    • jens m
    • Not Ranked
    • Joined on 04-17-2007
    • munich, germany
    • Posts 53
    hi craig and chris!
    good work craig!
    company tangband is doing some very good widerange speakerchassis with 8cm diameter, they´ve got some shielded ones as well.
    they sound very good and their frequency range goes up to 20khz, which the maplin one won´t manage.
    they offer models with different thiele small parameters, it would be interesting which would be the best parameters for a good bassreproduction in the log line construction, which seems to be a kind of strongly damped open baffle in pipe form Confused.
    greetings from munich
    jens
