1st March February 2012
Latest post 01-26-2009 6:57 PM by BeoNut1. 20 replies.
01-26-2009 9:54 AM
ChrDH
- Joined on 04-16-2007
- Denmark
- Posts 493
When will the Beovision 8-40 arrive?
Hi there
My aunt and uncle had a beovision L5500 which stopped working a few days ago. They were thinking of getting a replacement anyway, and also want a Harddisk-recorder of some sort. I mentioned a Beovision 8-32, but that is probably a bit too small, When will the Beovision 8-40 inch arrive?
best regards
Christian
Beosound Ouverture, Beocenter 9000, Beovision MX6000, Beocord VX7000
hampeman
- Joined on 05-13-2007
- Sweden
- Posts 40
Re: When will the Beovision 8-40 arrive?
I can recommend BV8-32. It´s nice, have a good picture, lovely sound. In my home it´s ok but probably a bit too small for a large house and a big room.
Edde
Christian
- Copenhagen, Denmark
- Posts 626
Very soon.
It is included in the new main catalogue.
Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
Addicted? Oh no.... ;)
Robert
- Joined on 06-13-2007
- Northern Ireland
- Posts 362
Christian, do you have the specifications for the BV8-40 if it is included in the new catalogue?
Robert.
Beofan2
- Joined on 07-31-2007
- Fredericia, Denmark
- Posts 313
I´ve already written the specs in an earlier posting but that was in the old forum. I belive BV8-40" to be launched marts / april. Soon....
It´s not magic - it´s Bang & Olufsen
Christian
- Posts 626
Yes.
Design: David Lewis Measure, weight: 106 cm x 63 cm x 26 cm, 26 kg (40") Color: Black/silver Power consumption: Typically 246 W; standby 0,5 W (40") High definition: Full HD (40") Screen type: 16:9 TFT LCD with high glare and low reflex treatment Resolution: 1920 x 1080 (40") Tuner: Analogue built in, 100/120 Hz update frequency (40") DVB-HD (40") Speaker: Stereo with center bass Optional: ML module
Robert
- Northern Ireland
- Posts 362
Beofan, I remember seeing your post, however I was interested in the specifics of dimensions of the TV, all the included connections, and whether it includes TIMER functionality. I believe this information would be included on the technical specifications normally seen in the catalogues.
Robert.
Robert
- Northern Ireland
- Posts 362
Christian:
Yes.
Thanks Christian, you must have posted while I was replying to Beofan! Do you know if the BV8-40 includes TIMER functionality? and any information on the Connections ie HDMI scart component?
Robert.
Christian
- Posts 626
+ 5.1 Digital Surround Sound built in. (Was hidden in the text)
Christian
- Posts 626
And that is all there is in the catalogue.
Regarding timer: I believe the current 26/32" has timer if you by the optional ML module.
Robert
- Northern Ireland
- Posts 362
Thanks Christian, I have a BV8-32 with the ML module, will have to check that out as I will need TIMER functionality if I get a BS5, as timers are set at the TV for it, as opposed to the audio system a la BS9000/BS3200.
Robert.
Christian
- Posts 626
You are welcome.
Instead of timer in the BV, it might be possible to use the soon to come BeoTime.
Robert
- Northern Ireland
- Posts 362
Thats correct, I had mentioned that as an option in a thread in the BS5 forum which discussed timer functionality. Will be interesting to see if its possible when Beotime is released. Out of curiosity, are any of the other new/soon to be released products included in the new catalogue?
Christian
- Posts 626
I don't know if it counts, but the BS5 / BM5 is (of cause) included. Otherwise no news really.
jk1002
- Boston USA
- Posts 1,620
The 32" doesnt have a timer, even wit a ML module. There is a timer menu entry, however that relates to the timer of a connected audio master I believe, have forgotten what it actually does but is definitely not a timer to control the TV
Robert
- Northern Ireland
- Posts 362
Thanks, I might consider trading in my BV8-32 for a BV8-40 on the basis of this info. I'm just awaiting the info on what connections it contains from a video perspective.
Robert
- Northern Ireland
- Posts 362
jk1002:
JK, I need the timer to control an audio system as opposed to the TV. Basically i want to set a wake up timer on the audio system (say BS5) in the living room, so as it goes off in the bedroom where I have a BL3500 only. I know BS9000 has its own timer function, but apparently the BS5 has to use the TV for timer functionality.
jk1002
- Boston USA
- Posts 1,620
I just looked at the booklet, the setting I am referring too actually controls the on and off of a STB. Since the 40" will be a based on a complete different chassis compared to the current TV range I guess we have to wait until they publish the user guide or somebody actually sees one on flesh at a dealer.
I think since the probably se the same chassis in BV 8 40", BV10 and BV7 32 (if it ever gets updated) chances are that a timer will be there.
Cheers
JK
Robert
- Northern Ireland
- Posts 362
After reading the ref book for the BS9000, I see that in an integrated AV setup, timers are set at the TV also. Therefore I am now wondering is it actually possible at all to set a wake up timer in my setup? JK, you should be able to test setting timers with your BV8 and BS9000, although you mightn't have a link room to simulate my setup. On a side note, does anyone know if you can only display the time on a BL3500 if there is a timer set in the setup?
BeoNut1
- Joined on 08-19-2007
- Mobile, AL (USA)
- Posts 226
Just out of curiousity, do we know if the BV-8 40" and the upcoming BV-7 Mark IV have LED backlighting?
M
Mark D
Page 1 of 1 (21 items)
