1st March February 2012
Latest post 02-03-2009 4:28 PM by Gordon38. 11 replies.
01-26-2009 9:19 AM
k984942
- Joined on 11-10-2008
- London, UK
- Posts 194
Hi All
I'm just about to masterlink two Avants and have decided that it may be easier to drill a hole through the wall and pass the masterlink and RF cable through. I did originally think of cutting the ML cable in two and using a junction box(to avoid having a hole big enough to get the ML plug through) but have now decided it might be easier to pass the ML cable with the ML end still on through the wall.
I haven't actually seen an ML plug in the flesh so can anyone let me know how big it is? I've borrowed a drill which I need to return before the ML cable arrives so I need to know how big a hole I need to drill.
32" RF VCR Avant, 2 x 28" VCR Avant, DVD1, Beocom 6000, Beo5, A9 Keyring!
dko7113
- Joined on 09-04-2008
- Copenhagen, Denmark
- Posts 104
If you measure the masterlink socket on your Avants, you will have a pretty good idea of its size...
My Beo: BeoCom 6000, BeoCom 2500, BeoCom 1401, BeoLine, BeoVision LX6000, BeoVision LX2500, BeoVision MS6000, BeoVision MX4002, BeoVision MX1500, DVD1, BeoSound 3200, BeoSound 1, BeoLab 4000, BeoGram 4500, BeoPort, BeoPlayer, 3x Beo 4, 2x BeoLink 1000, V Terminal, Form 2, Light Control 2, BeoTime
k984942
- London, UK
- Posts 194
How embarrassing! You're quite right! Just didn't think of that
Craig
- Joined on 03-29-2007
- Costa Del St Evenage
- Posts 4,855
Think I would stick with the junction box idea. It will require a much smaller hole. Masterlink plugs are 30mm at the widest point.
Craig
For millions of years, mankind lived just like the animals. Then
something happened which unleashed the power of our imagination. We
learned to talk and we learned to listen..
dko7113
- Posts 104
So would I!
And it is not a hard job to connect the cable in the junction box, if you are not having 10 thumbs...
/Erik
bayerische
- Joined on 12-11-2007
- Helsinki, Finland
- Posts 3,593
Craig:
Craig
I was going to suggest the same thing.
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
dko7113
- Posts 104
Did you short-circuit the White/Blue and Pink and interconnect all ground terminals, which is automatically done in the junction box?
/Erik
Nickyg63
- Joined on 08-28-2007
- Nottingham
- Posts 628
one thing I would like to add is when buying a masterlink junction box get a large as its very difficult to fit all the wires into a small!! Its a very straightforward job you get the tool with the box. Hope that helps
Nick
Quim43
- Joined on 11-15-2007
- Tarragona (Catalonia)
- Posts 1,030
dko7113:
/Erik
I have this short-circuit in another part of my ML installation.
majand
- Joined on 02-26-2008
- Helsinki
- Posts 72
How about bending, carefully, the connetor lengthwise to the cable and maybe use some tape to keep it that way. Then it should go through a smaller hole than the widht of the connector.
Pekka
Page 1 of 1 (12 items)
