1st March February 2012
01-26-2009 8:12 AM
Ansgar18
- Joined on 12-19-2008
- Posts 6
Beolab 8000 + non-B&O sources
Hi
I have just inherited a pair of Beolab 8000 and would like to know the best way to link them to a non-B&O source
Greatul for rapid answers
Morten
Evan
- Joined on 12-15-2008
- Ohio | USA
- Posts 2,601
Re: Beolab 8000 + non-B&O sources
First off, welcome.
I have the reverse of you're situation, I have a BeoSystem4500 which now runs JBL floorstanders. I run the B&O signal through a Yamaha Natural Sound R-7, which then makes the connection possible.
For you, however, things should be much easier. As familiar as I am with B&O speakers (not with the BL8000 unfornutely), they should also be able to be supported by two bare wire leads in addiotion to the power link. The only B&O speakers that I know for sure that have this feature are the BeoVox 5000s.
I'm sure more informative replies will follow.
kallasr
- Joined on 04-19-2007
- Willich, NRW, Germany
- Posts 1,077
Using RCA/Cinch cables and the pre-out of your amplifier (so - non amplified output), in theory. Not all AVR work, for example. I always had a hum I couldn't get rid off.
But worth a try!
Remember to set the speakers to line!
Ralf
My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD, Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
Evan
- Ohio | USA
- Posts 2,601
Yes.
Also I believe switching to "line" mode renders the speakers as passive, they will no longer be active as they will be solely powered by you're receiver or what have you.
kallasr
- Posts 1,077
No, this is not true! You use pre-outs to line-in.
Ralf
Ansgar18
- Posts 6
Thanks to you guys for helping out
Great help
Morten
Steve at Sounds Heavenly
- Joined on 05-18-2007
- In the cable workshop, Melton Mowbray, UK
- Posts 356
Ralf is correct, the Beolab 8000 remains active when in Line mode, the difference is that they no longer switch on when the B&O source triggers them. Instead, they listen for sounds through the audio channel and switch on automatically, staying on until the music has been silent for 3 minutes, when they go back into standby.
They do need to be connected to volume-controlled pre-out (ie. non-amplified) sockets to avoid damaging the speakers.
Best regards,
Steve.
Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
Page 1 of 1 (9 items)
