Latest post 01-26-2009 5:09 AM by Spiros. 4 replies.
Page 1 of 1 (5 items)
  • 01-25-2009 6:33 AM
    Looking for option in servicemenu HDR-2
    When recording from the STB there is a problem. The decoder has to startup before the recording can start.
    This proces takes 45 seconds and the STB did not proces the channnel number send by the HDR-2.
    The manual of the HDR-2 told me that there is an option in de servicemenu to solve this problem. I know how to enter the servicemenu, but not witch option and the value.
    Can someone tell me what to do?
    Piet
  • 01-26-2009 3:02 AM In reply to
    Re: Looking for option in servicemenu HDR-2
    Who has the answer to this challenge??
  • 01-26-2009 3:27 AM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Hi Piet.
    I see you are a gold member. Why don't you download the service manual which is in English?
    It's under the products -> user & service manuals-> Digital media -> Hard disc recorders -> HDR2 and you got it!!
    Best regards
    Spiros
  • 01-26-2009 4:28 AM In reply to
    Thanks Spiros. I forgot about the manual. I have red it now and the entry I have tried yesterday should be the right one.
    Menu AV Board, then M2 Information. It is the following option:
    STB TIMER Is default set to 0 but can be altered if timing problems occours during start up with certain Set-top Boxes.
    Yesterday I tried this. The number can be between 0 en 255. Not known what it represents (seconds, minutes, or something else).
    I have tried number 2 (suppose it represents minutes). Result: nothing
    I have tried number 60 (suppose it represents seconds). Result: decoder did't start and the 'record' indicator on the HDR-2 was flashing. No recording was made.
    So I am on track, but what is the right number???? I don't know. It is a lot of work to try the all (255 numbers).
    Does anyone know the right number and what it represents??
    Piet
  • 01-26-2009 5:09 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Sorry I can't help more!!!
    But maybe Keith will!!
    Best regards
    Spiros
