Latest post 01-29-2009 7:17 PM by Movie. 5 replies.
Page 1 of 1 (6 items)
  • 01-24-2009 10:00 AM
    • Movie
    • Top 500 Contributor
    • Joined on 04-18-2007
    • Posts 90
    Beo5 Change Set Up
    I hope some of you experts can advise, this question is from someone who is useless with PCs so sorry if it is  stupid.
    My dealer has set up Beo5 but I need to make some changes to it now, how can do this without mucking up what he has already done.
    Can I save his settings to Config. tool, and then edit  or add too.
  • 01-24-2009 10:38 AM In reply to
    Re: Beo5 Change Set Up
    You cannot read the settings from the remote itself. You would need the config software and also need to get the configuration.xml file that corresponds to your remote from your dealer. He can email it to you.
    p.
  • 01-24-2009 11:06 AM In reply to
    • Movie
    • Posts 90
    Thank you Phil.
  • 01-29-2009 5:10 PM In reply to
    • Movie
    • Posts 90
    My dealer set up Beo5, will I lose his settings if I  try and up load my own.
  • 01-29-2009 6:17 PM In reply to
    Yes. But your dealer can give you the config file, you can copy it to your PC, and then you can modify it.
  • 01-29-2009 7:17 PM In reply to
    • Movie
    • Posts 90
    Thanks again Phil.
