Latest post 01-25-2009 2:27 PM by Spiros. 14 replies.
Page 1 of 1 (15 items)
  • 01-24-2009 6:59 AM
    • Emil
    • Top 500 Contributor
    • Joined on 05-18-2007
    • Stockholm, Sweden
    • Posts 98
    Another link tv question
    I recently purchased a second hand BV7-32 MKI and are now struggling to incorprate in to my existing link system. Any advice would be highly appreciated. My setup are as follows.
    Main room: BV5 MKI used as a master
    Room 2: BV 7-32 connected via ML and RF to the BV5. 7-32 is set to option 6
    Room 3: BV 6-26 MKI connected via ML and RF from the BV 7-32 link out to the BV 6-26. BV 6-26 is set to option 4.
    My initial problem is that if I use the remote in room 3, the tv in room 2 is also reached by the remote. Thats the reason I have set the BV 6-26 to option 4 (i.e. it should only respond to link commands. However, I have noticed that when i press link + tv in room 3, the tv in room 2 also power up. Is there anything I can do to avoid this? In fact, it seems as if the BV7-32 is the first one to start up and then I have a picture on the BV 6-26 despite the fact that I pressed link + tv. This also affects other functions of the tv:s If I want for instance wants to turn the tv to the right of left using the "stand" funtion on the Beo4, both tv:s are affected.
    Surely there must be a way to avoid this? I can however not find out what I am doing wrong.
    Inflagrante
  • 01-24-2009 11:51 AM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Re: Another link tv question
    From what I understand there is a very short distance between the two rooms?
    Best regards
    Spiros
  • 01-24-2009 1:06 PM In reply to
    try to put them on option 6 ....
    when your Black Label begin to taste like juice just take shot or two of Absinthe and after that quench with some vodka, if you still feel juice like take beer with grappa !
  • 01-24-2009 3:29 PM In reply to
    • Emil
    • Stockholm, Sweden
    • Posts 98
    True, there's not much of a distance between the two rooms and unfortunately no door to close either.
    As regards putting them into option 6, would that not make them responde to the same commands from the remote?
    Inflagrante
  • 01-25-2009 12:23 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    My guess is whatever option you put to both of the them (e.g. 4-5-6) you will have the same problem.
    However just an idea popped out. Try to use this signal reducer they have on B&O shops. It's a plastic cup you put on top of Beo4 and this way you have a significantly lower ir transmition.
    another idea but not sure if this would work is to use a Beo5. Maybe in this case it could work as well.
    Best regards
    Spiros
  • 01-25-2009 3:40 AM In reply to
    Spiros:
    use a Beo5
    Beo5's signal is a lot stronger than the Beo4... that would be worse.
    I have a similar problem, with semi-open rooms, and I am fine if I use Beo4, but when I use Beo5 everything goes off at the same time.
  • 01-25-2009 6:48 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Indeed, but wouldn't a signal reducer on the Beo4 work for both of you?
    Best regards
    Spiros
  • 01-25-2009 7:42 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    The signal reducer would have the complete opposite effect - I find them to be far too directional!
     Weekly top artists:
  • 01-25-2009 11:21 AM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    ???????????????????????????? but they have it as the name says. reducer!!!
    Best regards
    Spiros
  • 01-25-2009 12:24 PM In reply to
    • Alex
    • Posts 2,990
    I think you may have misunderstood me Spiros, what I meant is that the 'Reduced range' caps make it very difficult to use as you have to point the remote control directly at the IR receiver.
     Weekly top artists:
  • 01-25-2009 12:51 PM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    Spiros:
    It makes them look a lot more attractiveHuh?
  • 01-25-2009 1:22 PM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Correct! and that might be a solution but of course some times will be hard!!!
    Best regards
    Spiros
  • 01-25-2009 1:23 PM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Laughing  Indeed Puncher, Indeed!!!!
    Best regards
    Spiros
  • 01-25-2009 1:55 PM In reply to
    • Emil
    • Stockholm, Sweden
    • Posts 98
    Hmm, a signal reducer could of course be a solution. However, I think I will play around a little bit more with the different option settings to start with. The funny thing is that I did nit have the same problem when I had my AV9000 in the same place as I have the BV6-26 now. But it was of course not linked to the system...
    And Spiros, I definetely agree with you. The AV9000 really is something special.
    Inflagrante
  • 01-25-2009 2:27 PM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Hello Emil.
    AV9000 is the SPECIAL TV regardless of whatever anything says.
    In my opinion whatever option you might use the problem will still be there.
    But i'm wondring why AV9000 did not get the signal? I think it should be irrelevant of being on the link or not.
    Maybe you can get a signal reducer from your local B&O store just to test it. I think it might save you a lot of time and puzzling!!!! And keep this post updated. It's quite interesting to know!
    Best regards
    Spiros
