Hi Leo
Thanks yes I have considered this as an alternative,
Only difference I guess is the power supply is more stable in the USA.
Where my equipment will be located is in a small village in the South of Taiwan so the power is a little unstable that is the only reason I though best to use the correct power supply.
All my B&O equipment (BS9000 BL8000 BL6000 BL4000) are currently at B&O Taipei been converted from 220v to 110v (I must say also at reasonable cost)
I have already sourced an 110v Power Supply (ebay) for my BG4500 and had the conversion done and it works fine.
But I now need to source an 110v for my BC4500
My impression of power transformers/converters was big and heavy, but I guess this has changed if you can buy one for US$15.00.
I will keep the transformer route as an option if I have no luck to source the actual power supply
Barry
