Latest post 01-28-2009 4:23 AM by stotty1111. 9 replies.
Page 1 of 1 (10 items)
  • 01-23-2009 3:05 PM
    • stotty1111
    • Top 75 Contributor
    • Joined on 12-16-2007
    • UK / France - Nth Worcestershire/Finistere
    • Posts 924
    • Gold Member
    Mcl 2P rewiring for 230/240 volt operation
    Hi All
    Just inherited one of the above of Canadian origin (family friend) - my quetion is, anyone out there with a service manual or a transformer wiring diagram to enable conversion from 120volt operation to 230/240 volt operation , can it be done if so help please!
    Trying to get it running to drive some pentavoxes!
    TonyHmm
    I always try to operate using/following the KISS principle --  Keep it simple stupid!
  • 01-23-2009 3:24 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Mcl 2P rewiring for 230/240 volt operation
    Hi Tony, have you looked at the service manual for the ML/MCL Converter? They may have the same transformer inside.
    CraigSmile
  • 01-23-2009 3:26 PM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    The service manual for the Beolink passive is on site which also covers "ML/MCL converter etc...." and according to it then it is definately possible to do this. I would imagine it uses the same transformer as the MCL 2P can used for the same application.
    Chris.
  • 01-23-2009 3:35 PM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Thanks both, forgot to add its a 1743 type
    Craig have an ml / mcl job unfortunately its in a box here in finistere but i can't remember which one! - so its  back to the pastis then!
    T
  • 01-23-2009 4:29 PM In reply to
    • Medogsfat
    • Posts 4,045
    Just done some digging and according to one source the Beolink passive was based on the MCL 2P so converting the voltage in the transormer should be pretty straight forward judging by the service manual.
    Having said all of this I'm not sure if the output of the MCL 2P would do penta's the justice they deserve.
    Chris.
  • 01-25-2009 11:28 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Thanks guys
    Think I'll take Chris's link and get a converter tranny at qabout £10 then have a play around with the onboard unit!!
    Tony
  • 01-26-2009 10:10 PM In reply to
    I've had it done by the local TV repairman..... I guess it can't be too difficult then!!!
    My B&O: 2009 Catalogue and Pricelist
  • 01-27-2009 3:53 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Where are you based i'm currently in france but returning in the near future if not too far distant maybe i could have a look?
    Tony
  • 01-27-2009 5:46 PM In reply to
    I'm in Australia (Melbourne)
  • 01-28-2009 4:23 AM In reply to
    • stotty1111
    • Posts 924
    • Gold Member
    Bravo - silly me i realized after send the message coz of the melb - what a pratt i am!!
    Ok can you open up the box an take a pic of the transformer end - p-m me with your email address and i'll return mine - don't think the forum can take quality pics onboard due to pixel total size limitations!
    salut
    T
