Yes, it is indeed a Terminal 6000.
I agree that it has a very similar circuit to the Terminal 5000 but not quite
the same... I have a fault in the button matrix and as the contact board is covered
in black plastic, I would prefer to look at a diagram to select
areas to attack rather than take it all apart.
Valve stuff is fascinating and exciting to work with but it does take time
to get it right and you do have to be careful. As you say, voltages as high
as those usually found in valve things should be respected.
I haven't had much time lately to work on the Beolit 39 but
the thread will, hopefully, soon be updated.
Thanks for your interest, greatly appreciated ! ![Yes - thumbs up](http://forum.beoworld.org/emoticons/21.gif)
