Latest post 01-22-2009 3:13 PM by Gordon38. 0 replies.
Page 1 of 1 (1 items)
  • 01-22-2009 3:13 PM
    Beoport as stand alone without PC for Squeezebox/Sonos?
    Hoping one of you pro's can help me out.. I have Beoport but do not use it any longer since I bought a Spueezebox duet.. Is it possible to connect the squeezebox directly to the beoport (standalone without PC) so when I press N.Music the Beoport just open the input and squeezebox is playing on my B&O setup? Currently the Squeezebox is connected to a BS 3000 in AUX but my BL 2000 do not react to BEO4 A.Aux and it would also be cooler to press N.MUSIC Cool
    ..I have of course tried, but it does not work quite the simple way - perhaps some programming or?..
    Filed under:
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
