Latest post 02-19-2009 1:52 PM by lloydern. 4 replies.
Page 1 of 1 (5 items)
  • 01-22-2009 11:48 AM
    Beolab 4. What do you guys think?
    Norsk:
    Hei alle sammen.
    Jeg vurderer å kjøpe meg et par BeoLab 4 til et linkrom men er litt usikker på om disse høytalerne er verd det. Hva mener dere?
    English:
    Hi everyone.
    Im considering buying a pair of BeoLab 4 speakers for a linkroom in my house. But im unsertain about the sound quality of these tiny speakers so i would like to know what you guys think?
  • 01-22-2009 1:48 PM In reply to
    Re: Beolab 4. What do you guys think?
    I think the Beolab 4 is a bit weak to be honest. I would far rather get a second hand pair of Beolab 4000s.
  • 01-23-2009 2:19 PM In reply to
    • Christian
    • Top 100 Contributor
    • Joined on 04-16-2007
    • Copenhagen, Denmark
    • Posts 626
    Jeg er egentlig enig med Peter, men synes det kommer an på, hvor og hvordan de skal stå.
    Jeg købte BL4 og er rigtig glad for dem. BL4000 synes jeg lyder bedre, men til min skrivebord ville de være alt for store, og derfor valgte jeg BL4.
    Living room: BV7-40 mkIV + V8000, BL5, BL3, BM1 and BS9000. Bedroom: MX3000 and BL4500 on MCL2-AV. Around: PentaIII, CX100 and MCX35 on ML/MCL + MCL2-A, BeoPort and BL4 on ML, BS3300 + M75 as stand alone, BC6000 + BC600 and BT1100, LC1, LC2, Beo4, Beo5 and BL1000, BS2 and A8, EarSet2, Apron, Coffee mugs, Enamel Bagdes, Bath towel, Keyring, Books, Lots of miniature and the Bottle opener. Office: BC2300 + BL2500 and BS3. Summer house: BS Century.
    Addicted? Oh no.... ;)
  • 02-19-2009 10:00 AM In reply to
    • Hank
    • Not Ranked
    • Joined on 04-17-2007
    • Posts 25
    I use a pair of BL4 as speakers to my TV and think they do a quite good work.
    But as speakers for a stereo, I think they are to weak.
    I have BL4, BL3 and BL 4000 and think BL3 is the most functional speakers for the money. It´s the moste expensive of the three but the sound is many times better.
    But as you say, for a link room BL4 might be enough.
    Best Regards Hank
  • 02-19-2009 1:52 PM In reply to
    Hei!
    Til et link-rom kommer det også litt an på hva du har av utstyr fra før. Kjøper du lab 4 eller 4000, trenger du også en Active og fjernkontroll i tillegg. Men har du egentlig vurdert Beolab 2000?
    Da slipper du Active som koster 2500,- NOK ca, og du trenger heller ingen egen fjernkontroll til rommet, siden den har nærbetjening av av/på, volum, cd, tape(tv), og radio. Lyden i lab 2000 er riktig så bra synest jeg, og jeg er sikker på at i et lite rom matcher den glatt lab 4.
    Lab 4000 er uansett er meget bra valg lydmessig. Kanonbra lyd, og uten tvil den beste høyttaler fra beo i forhold til pris vs ytelse. Brukt bør de ligge på mellom 6-10.000 NOK. Forøvrig har Senter TV-service i Oslo til salg en brukt lab 2000 til 3599,- NOK.
     Jeg har selv to stk lab 2000 som jeg er strålende fornøyd med, en på kjøkkenet og en på kontoret.
    Lykke til
    Lloydern....
    Anything but Beo isn't an option...3-32, Overture, DVD1, Beomedia, V8000, lab 4000, 2 x lab 2000, 2 x lab 6000 & lab 11.
