Latest post 01-19-2009 3:48 PM by dko7113. 7 replies.
Page 1 of 1 (8 items)
  • 01-19-2009 7:33 AM
    help with playing music from PC through Beosound 3000
    Hi there I'm new to this forum, but have a question.
    I have been the owner of a besound 3000 for 5 years now, and i've been happy! Now however I'm tearing my hair out of my head as I'm trying to get my PC to play sound through the AUX port. I've bought the 5 pin socket adaptor which fits nicely in the slot. I have programmed my BEO4 so that it says A.AUX and it turns on the Beosound nicely when pushing the button... so theres only one thing missing...SOUND
    There is no sound coming out of the speakers... except if I turn up the volume to max (72) then I can hear the music just slightly. So I'm sure theres a connection... but now I don't know what to do. Please help. (and yes I have also turned up the volume on my pc.)
  • 01-19-2009 7:37 AM In reply to
    • Ignace
    • Top 25 Contributor
    • Joined on 03-30-2007
    • Moderator - NL
    • Posts 2,749
    Re: help with playing music from PC through Beosound 3000
    welcome to BeoWorld !
    The adapter you mention, does it have 4 RCA plugs (2 in, 2 out) ?
    If so, perhaps you've connected the line-out instead of line-in ?
  • 01-19-2009 8:03 AM In reply to
    Hi thanks for a quick reply. It have 5 pins I don't now the technical expression, but I will post a picture of it... one moment...
  • 01-19-2009 8:11 AM In reply to
    Here are the pics... in my case it says more than a 1000 words ; )
  • 01-19-2009 8:57 AM In reply to
    The cable looks correct, but it may still not be the type you need. The DIN connector (5-pin) has both stereo inputs and outputs, but the 2 RCA's can only be connected to one or another of them. I suspect the cable you have is built to get signal from the DIN to the RCA's. You'll either have to swap it for the other type, or get an adapter with four RCA's; then you can use it in both directions.
    -mika
  • 01-19-2009 9:10 AM In reply to
    • Ignace
    • Moderator - NL
    • Posts 2,749
  • 01-19-2009 9:55 AM In reply to
    Thanks for the replies - they were all very helpful. I'll buy another cable.
  • 01-19-2009 3:48 PM In reply to
    • dko7113
    • Top 500 Contributor
    • Joined on 09-04-2008
    • Copenhagen, Denmark
    • Posts 104
    • Gold Member
    if your BeoSound 3000 is the large clamper version, you could consider connecting a BeoPort…
    It is a more expensive solution, but you will be able to control your pc with the Beo4 remote, and you will get access to a lot of Internet radio stations.
    Regards,
    Erik
    My Beo: BeoCom 6000, BeoCom 2500, BeoCom 1401, BeoLine, BeoVision LX6000, BeoVision LX2500, BeoVision MS6000, BeoVision MX4002, BeoVision MX1500, DVD1, BeoSound 3200, BeoSound 1, BeoLab 4000, BeoGram 4500, BeoPort, BeoPlayer, 3x Beo 4, 2x BeoLink 1000, V Terminal, Form 2, Light Control 2, BeoTime
