Latest post 01-23-2009 2:54 PM by Craig. 10 replies.
Page 1 of 1 (11 items)
  • 01-18-2009 2:18 PM
    Can the xbox 360 be controlled by the beo 4
    Hi:
    I just want to be able to power it on and off really.
    Graham
  • 01-22-2009 9:38 AM In reply to
    Re: Can the xbox 360 be controlled by the beo 4
    anyone?
  • 01-22-2009 1:46 PM In reply to
    • Spiros
    • Top 50 Contributor
    • Joined on 09-03-2007
    • Thessaloniki GREECE
    • Posts 1,088
    • Gold Member
    Hi there. I think it's not possible with Beo4 unless you use the Linktronic device which of course will ive you more features!
    Best regards
    Spiros
  • 01-22-2009 2:37 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Graham, If you are a really good shot, you could try throwing your Beo4 at the on/off switch.
    Attatch it to a long elastic if you want to repeat the operation.
    Andy T.
    Poor me, never win owt!
  • 01-22-2009 3:46 PM In reply to
    • Craig
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    spirost:
    Not 100% sure that would work either. As the wireless xBox 360 controllers work by Bluetooth, not Infra Red.
    CraigSmile
  • 01-22-2009 4:00 PM In reply to
    • V13WNG
    • Top 500 Contributor
    • Joined on 06-11-2007
    • Eastbourne, East Sussex, ENG
    • Posts 200
    Aren't the XBOX 360's turned on/off wirelessly anyway using the 'X' button on the controllers?
    If so, what would a Beo 4 gain you, may I ask?
    Muchos Gracias Cool
  • 01-22-2009 4:09 PM In reply to
    • Craig
    • Posts 4,855
    A14BEO:
    Yes, they are Matt.
    CraigSmile
  • 01-22-2009 5:41 PM In reply to
    • Spiros
    • Posts 1,088
    • Gold Member
    Nothing to do with these game machines my  self!!!! Probably my son in the next 5-10 years Big Smile
    Best regards
    Spiros
  • 01-23-2009 4:45 AM In reply to
    I didn't know that - I was given my 360 with no manual but I don't know how that would work - do you just hold the X down for a while?
    There is def an infa-red bulb on the front of the machine though.
    What is a lintronic device - I only know of a light control system called a lintronic. Sorry if these are very basic questions.
    Graham
  • 01-23-2009 8:49 AM In reply to
    • Craig
    • Posts 4,855
    Graham1982:
    Graham
    They do make a light control system, but also do an IR converter. This allows you to control non B&O devices with a B&O remote. Search the forums as there should be quite a few posts about it.
    CraigSmile
  • 01-23-2009 2:54 PM In reply to
    • Craig
    • Posts 4,855
    Graham, you can dowload an instruction manual HERE.
    CraigSmile
