Latest post 05-23-2007 2:36 PM by ZeTof. 3 replies.
Page 1 of 1 (4 items)
  • 05-23-2007 11:37 AM
    Beolab 4500's Display isues
    I have a pair of BL:4500's  connected up to my BS3000 . The issue that i have is that at present and for as long as i have had them, i can't seem to be able to see the led display info that is at the bottom right hand corner .Is this a conectivity issue or am i missing something here?
  • 05-23-2007 12:11 PM In reply to
    Re: Beolab 4500's Display isues
    I assume you have the Beolab 4500's connected using the powerlink sockets and the switch is either in L or R
    I am assuming the switch is not in the "A" position ?
    In standby there should be a small red led next to the display
    Regards Keith....
  • 05-23-2007 12:28 PM In reply to
    And the switch on the side of the speaker needs to be in the Audio position. You need to use fully wired Mk2 powerlink cables.
    Regards Graham
  • 05-23-2007 2:36 PM In reply to
    • ZeTof
    • Not Ranked
    • Joined on 05-23-2007
    • Paris, France
    • Posts 15
    ... and you have to reset BS3000 and Blab4500 to be sure it works. (unplug power cable of both unit until stby led disapear, and re-plug them).
    (sorry for my english...)
    http://zetofzone.free.fr
