Latest post 01-19-2009 6:59 AM by david707. 5 replies.
Page 1 of 1 (6 items)
  • 01-18-2009 4:25 AM
    DVD1 software
    I have DVD1 typnr 4620 and sw 1.3.
    Can I change sw by my self?
  • 01-18-2009 4:42 AM In reply to
    Re: DVD1 software
    Silly question from me! Why? The most up to date software is 1.6 for this model and only fixes a problem where the DVD can stop playing half way through. I don't think there are other advantages. It means replacing a chip on PCB1 but I am sure you could do this - if you had the chip! Not much inside the DVD1!
  • 01-18-2009 4:44 AM In reply to
    Re: DVD1 software
    Peter :
    "only fixes a problem where the DVD can stop playing half way through"
    It does this!
  • 01-18-2009 5:11 AM In reply to
    Re: DVD1 software
    Peter :
    A chip? Is that all it takes? I thought there was a problem with overheating which required completely new boards/re-design etc. Is there a B&O part number for the chip?
  • 01-18-2009 5:36 AM In reply to
    Re: DVD1 software
    Yes - 8344094 - but whether B&O will sell it to you is another matter. Get the firmware updated at the same time - 7.23b - that is changed by using an update disc in the player - stops the odd menu appearing.
  • 01-19-2009 6:59 AM In reply to
    Re: DVD1 software
    Many thanks Peter. I have two and both have the freezing problem - they are also very fussy about DVD-RW's
    David
