Latest post 04-02-2008 2:46 PM by Argee. 6 replies.
Page 1 of 1 (7 items)
  • 05-23-2007 8:23 AM
    • Kevin
    • Top 50 Contributor
    • Joined on 02-15-2007
    • Moderator
    • Posts 1,256
    Usefull links for bits and bobs
    Thought this might be a usefull thread to have.
    This will be for links to sites where components and the other usefull bits are available.
    Put up a post with your link and I will edit it into this post:
    Capacitor and belt Kits: PM to Dillen
    General Electronics parts:
    Germany
    www.Segor.de
    www.Reichelt.de
    http://www.rsonline.de
    United Kingdom
    http://rswww.com
    http://uk.farnell.com
    www.cpc.co.uk  - owned by farnell but sells more domestic/consumer electronic pars/goods.
  • 05-23-2007 8:47 AM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    Re: Usefull links for bits and bobs
    Also www.cpc.co.uk  - owned by farnell but stocks more domestic/consumer electronic parts/goods, similar to
    www.maplin.co.uk. As an aside cpc is also quite good at white goods spare parts.
  • 05-23-2007 3:33 PM In reply to
    Germany:
    Electronic parts
    www.Segor.de
    www.Reichelt.de
  • 05-24-2007 3:34 PM In reply to
    Hello,
    The Netherlands:
    http://www.bmm-electronics.nl
    http://www.deaudiofabriek.nl
    http://www.voti.nl
    United Kingdom
    http://www.hificollective.co.uk/
    Kind regards
    Joost Declercq
    Gent (B)
  • 08-02-2007 1:15 AM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    Re: Useful links for bits and bobs
    Great Idea Kevin!
    Here are a couple of my regular suppliers:
    Suppliers in the USA (export worldwide - very reasonable shipping costs)
    www.mouser.com
    www.digikey.com
    The above 2 are massive suppliers, which means their stock has a high turnover and is always fresh from the factory - Nichicon, Panasonic, Wima, Xicon.
    www.percyaudio.com
    Percy has all the top-name audio-grade capacitors - Blackgate, Elna Silmic, Nichicon Muse, Auricap, Dynamicap, Solen & Axon and others.
    Regards
    Menahem Yachad
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
  • 11-27-2007 3:44 PM In reply to
    • Medogsfat
    • Joined on 02-21-2007
    • Posts 4,045
    Alternative solution to CD/tape adaptor.
  • 04-02-2008 2:46 PM In reply to
    • Argee
    • Not Ranked
    • Joined on 03-31-2008
    • Waiuku, New zealand
    • Posts 11
    In New Zealand.
    http://www.rsnewzealand.com
    http://www.jaycar.co.nz/
    http://www.surplustronics.co.nz
    Surplustronics got a lot of old stock sitting around too and is cheap, once bought a capstan motor for my Akai reel to reel brand new for $5!
