Sorry, I did not buy it. I could get it as for low as 100 SKR= 10 Euro. But I did not now if it worked, the backpiece was torn. It was on an auction on the cheap section where the only way to bid is to send in a bid, highest bid wins. Lowest bid 100 SKR. You can´t follow the auction and bid higher. I don´t like this system aswell as I was not really interested personally, I was more into make some money(while I am quite poor at the moment).
I was maybe 2 weeks ago the auction was, I don´t really know what they have done with it, if they give to charity or toss it. Anyway, for those who are interested I can give you contact info on the auction company so you can contact and check. The auction company is located in Helsingborg, Sweden. Not very far from Copenhagen Martin.
It does NOT look like this one(if it had, I would have bought it): http://www.bang-olufsen.com/image-gallery?pid=198&descr=Master+40+K,+1939
Best regards
Filip
