I did not expres my self very good, I did of course try your recomendation also. With that setting I can not control the volume when I start the CD. Also the TV starts only in mono.
It suddenly makes sense that there were no difference to switch to opt.3
I have now systematically tried all combination of settings and I now hav v.opt.1 and a.opt.2 with this setting the CD works fine and the TV turns on in 3 channel mode, the Pentas starts automatically and if I want 5 channel I only press sound5. Good enough!
The beotech side is great, lot of information there I had forgotten that one!
Now when I finally have this working it is time for instalation of the next gadget. BeoLink PC2, I am not sure how, or even if this will work with my setup. But probably I will find out soon with some help from Beoworld
Thank you for the support!
