Latest post 01-23-2009 2:37 PM by mor. 3 replies.
Page 1 of 1 (4 items)
  • 01-15-2009 9:23 AM
    • mor
    • Top 500 Contributor
    • Joined on 04-19-2007
    • Cologne
    • Posts 104
    BeoCenter 2 Problem
    Hello Everyone,
    after power went out in our house the other week due to the builders, my Masterlink system doesnt operate as before anymore: The BeoCenter2 (option Audio 0) that's connected to my BeoVision5 (option Video 2) does not send any audiomaster functions into the system anymore: when I press DVD it works just fine (BeoCenter2 starts and TV shows DVD) - but neither radio nor CD button trigger any functionality. The TV will simply stay in TV mode :-( ... same for the linkroom Avant (option Video6) ... it cannot access the masterroom BeoCenter2 anymore either...
     Has this happened to anyone else before? Any hint greatly appreciated
    mor
    Filed under: ,
  • 01-15-2009 12:07 PM In reply to
    • Opman
    • Top 200 Contributor
    • Joined on 12-31-2007
    • Cheshire, UK
    • Posts 323
    Re: BeoCenter 2 Problem
    Hi Mor
    Depending on how long the power was off due to the builders, it is likely that one or more of your products pin codes have become active.
    Have you entered the pin codes for all your main products? If you have a link system, it's a good idea to remove the masterlink plugs before entering the pin codes.
    I would enter the pin codes, then unplug from the power to plug the masterlink back in and then re-connect the power.
    Opman
  • 01-15-2009 12:10 PM In reply to
    Should it be option link 6?
  • 01-23-2009 2:37 PM In reply to
    • mor
    • Cologne
    • Posts 104
    Have unplugged all. Have re-optioned everything - nothing worked ... next morning - elfs must have been in overnight: everyworked fine again!
