Latest post 01-16-2009 3:59 PM by Steve at Sounds Heavenly. 9 replies.
Page 1 of 1 (10 items)
  • 01-15-2009 7:50 AM
    Beolab 3 as PC speakers
    What do I need to use my BL3s as PC speakers or iMac speakers? Do I need DAC?
    - Christian
  • 01-15-2009 7:57 AM In reply to
    Re: Beolab 3 as PC speakers
    You should just need the correct cable and switch the speakers to line input.
  • 01-15-2009 8:13 AM In reply to
    • Puncher
    • Top 10 Contributor
    • Joined on 03-27-2007
    • Nr. Durham, NE England.
    • Posts 9,588
    meandmyshadow:
    I'm not sure of the internal soundcard quality of the Mac - you may want to invest in an external DAC to do the BL3's justice.
  • 01-15-2009 8:14 AM In reply to
    • Puncher
    • Posts 9,588
    Double post.
  • 01-15-2009 8:37 AM In reply to
    "You should just need the correct cable and switch the speakers to line input."
    What would be a correct cable?
  • 01-15-2009 12:26 PM In reply to
    Mini jack to 2 powerlink though you will need to see your dealer to make sure this is available. I use BL3s with my PowerMac and the soundcard is fine. I do use a Beoport though as it allows me to pipe the music to the rest of the house as well. Not very expensive and allows control of iTunes with a Beo4.
  • 01-16-2009 6:12 AM In reply to
    Hi chrisped,
    You need a stereo 3.5mm mini-jack to connect to the PC and two 7 pin DIN plugs for the Beolab 3's.  Don't use a cable with 5 pin DIN plugs fitted, as this won't have the voltage reference pin connected, so it may cause humming noises through the speakers.
    Some dealers are selling a combination of three cable adapters to do this job, which can be rather unsightly in some applications.  A little bit of searching (eBay, internet, etc) will get you a high quality cable without any need for adapters.  If you prefer to buy from a franchised dealer, you may want to ask them if they sell cables other than the stock B&O offerings, as the choice of companies supporting this market is much wider than it was a couple of years ago.
    Best regards,
    Steve.
    Sounds Heavenly Cables are proud to be a sponsor of the BeoWorld Forum!
  • 01-16-2009 6:32 AM In reply to
    Thanks Peter, Steven & everyone.
    I will now go hunting for that cable.
    Christian
  • 01-16-2009 1:42 PM In reply to
    I'd ask Steve if he has one! His company does a good line in cables.
  • 01-16-2009 3:59 PM In reply to
    Thanks Peter!
    I was trying to be helpful without wanting to promote my own products, so I appreciate the recommendation!  A growing number of franchises are also stocking my cables, so there is now a better choice available on the high street, as well as online.
    I'm always happy to answer any enquiries, especially regarding cabling... Big Smile
    Best regards,
    Steve.
