Latest post 01-14-2009 2:03 AM by Keith Saunders. 1 replies.
Page 1 of 1 (2 items)
  • 01-13-2009 11:18 PM
    beo5 config for Panasonic Blu-Ray
    Panasonic Blu-Ray owners,
    How do you have your Beo5 configured? I've got Panasonic Blu-Ray selected as the device on my BeoSystem 3, but have no ability to skip chapters or to fast forward/rewind, which would ideally be controlled by the outer ring of mechanical buttons on the Beo5.
     Also, has anyone managed to get the Beo5 to support the PIP options, or the A(red) B(green) C(blue) and D(yellow) Blu-Ray remote buttons?
     Thanks.
    -- Paul
    Filed under: , ,
  • 01-14-2009 2:03 AM In reply to
    Re: beo5 config for Panasonic Blu-Ray
    Paul,
    Depending how you set up your Panasonic XML file and assuming you have the latest firmware 1.40a, then you should be able to program all the options you have listed.
    Fast forward and rewind can be programmed, but if you are using the RAW protocol there are still some issues to be resolved which means holding a button down to do a repeat does not work. If this product uses NEC or RC5 protocols then the repeat does now work.
    Regards Keith....
