Latest post 01-14-2009 1:44 PM by stampfki. 4 replies.
Page 1 of 1 (5 items)
  • 01-13-2009 2:42 PM
    Airport Express Optical Out into DDS BV3-32
    Hello,
    I would like to hook up the AE directly to one of the two coax digi. inputs backside of the Beovision 3. The DSS handle the sound well and outputs it without any Problems to the connected Beolabs 5000. But I cannot tranfer the sound into the other rooms via Masterlink. Has it to do with the Linear PCM stream coming from the AE? I thought the DSS module converts that into a regular Stereo signal?
    Any ideas???
  • 01-14-2009 3:44 AM In reply to
    • kallasr
    • Top 75 Contributor
    • Joined on 04-19-2007
    • Willich, NRW, Germany
    • Posts 1,077
    Re: Airport Express Optical Out into DDS BV3-32
    I am afraid no digital sound is transfered via the link system...
    Had the same issue with movie sounds.
    Ralf
    My Beo: Beosound 3000, Beolab 4000, Beo 4 DVD,  Beolab 5000/Beomaster 5000, Beovox S45.2 with Stands, Beosystem 7000 black with Beolink 7000, Beolink 1000, F1000 (3 cubes), Beovox 5000, Beovox 3000, Attyca 1.
  • 01-14-2009 10:33 AM In reply to
    Ok. But when I am watching a DVD e.g., I select AC3, which seems operatable by the MAsterlink. Al least setting to AC3 allows sound on the BV1. But when I set on Dolby Digital, the system is quiet. So I don't really understand why the stream from the AE via Toslink is not possible to handly, even it is a Stereo signal.
  • 01-14-2009 12:44 PM In reply to
    • Luigi
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Figueres (Spain)
    • Posts 3,013
    Dolby Digital o DTS? I can send DD to masterlink room (BV1), but not DTS. Also, it's not possible to listen PCM stereo through digital coax of DD module of BV3.
    Luis
  • 01-14-2009 1:44 PM In reply to
    Luigi, it is possible to here it at the BV 3 connected speakers! I just don't understand that this works, but not transfering it to Masterlink room
