1st March February 2012
Latest post 05-23-2007 4:25 PM by Jandyt. 14 replies.
moxxey
- Joined on 04-14-2007
- South West, UK
- Posts 2,360
Re: BeoVision 7 cleaning the AR screen
avus17: Has somebody any experience with cleaning the screen on BV7? I have a lot of troubles with cleaning it. Is it possible to buy some special solution for cleaning the AR screens?
Dead easy - just wet some paper towel, wipe clean. Take some dry paper towel and quickly dry.
9 LEE
- Joined on 02-14-2007
- Moderator - UK
- Posts 5,223
We use 50% diluted good quality vehicle screenwash along with Kitchen Roll.
Works perfectly every time!
Lee
PhilLondon
- Joined on 04-16-2007
- London
- Posts 2,545
When we were visiting the Struer factory, I asked the guy who was looking at the production of the BV7 screens. He said NO ALCOHOL, or max 5%. He recommended to use very diluted washing up liquid.
Tom
- Luxembourg
- Posts 3,175
moxxey: Dead easy - just wet some paper towel, wipe clean. Take some dry paper towel and quickly dry.
that's how I do it too. but I use paper towel with only a few drops of whater and rub until the screan is clear. works very well
Music washes away from the soul the dust of everyday life. - Berthold Auerbach
Iconic-AV
- Birmingham UK
- Posts 902
i use 1 damp e-cloth using only water, then buff it off with a dry e-cloth, it stays smear free for ages its a specially textured cloth that needs no chemicals whatsoever no matter how diluted, i use them on everything, and for glass they are perfect jay
beodim
- Joined on 04-17-2007
- Switzerland
- Posts 130
jay: i use 1 damp e-cloth using only water, then buff it off with a dry e-cloth, it stays smear free for ages jay
What is e-cloth? Sorry for my ignorance.
BV7-40, BC6-26, DVD2, BCordV8000, BS4, BS2, BS Ouverture, BC9500, BM8000, BCord9000, BL8000, BL6000, BL2, BL3, BVox4500, BCom6000, Beomedia1, BCom5, Serenata
Tom
- Luxembourg
- Posts 3,175
jay: i use 1 damp e-cloth using only water, then buff it off with a dry e-cloth, it stays smear free for ages its a specially textured cloth that needs no chemicals whatsoever no matter how diluted, i use them on everything, and for glass they are perfect jay
I think I'll give these a try and order some. There are different ones.Which one(s) do you use?
9 LEE
- Moderator - UK
- Posts 5,223
In our defence, you lot probably keep your screens a lot cleaner than most people..
When you get a screen in that's been licked by household pets, prodded with biscuits by unruly children, then prodded by customers greasy fingers - kitchen roll just doesn't do the job!
Lee
Iconic-AV
- Birmingham UK
- Posts 902
tom: jay: i use 1 damp e-cloth using only water, then buff it off with a dry e-cloth, it stays smear free for ages its a specially textured cloth that needs no chemicals whatsoever no matter how diluted, i use them on everything, and for glass they are perfect jay
There are 2 types, a normal one for everything and a finer one for glass, although IMHO there is no difference so i never bother using the glass one, ideally you need 2 normal e-cloths, one to use damp and the other to buff with, thats where the different colours are useful. let me know what you think when you try them
Tom
- Luxembourg
- Posts 3,175
jay: ... if only they did one with the beoworld logo on
Hey Lee, wouldn't e-cloths be a good merchandising idea to expand our (your) Beoworld Gifts?
Iconic-AV
- Birmingham UK
- Posts 902
9 LEE: In our defence, you lot probably keep your screens a lot cleaner than most people..
Lee
that reminded me of what my beocom 2 when through to get my avatar licks, biscuits then prods
Iconic-AV
- Birmingham UK
- Posts 902
tom: jay: ... if only they did one with the beoworld logo on
Hey Lee, wouldn't e-cloths be a good merchandising idea to expan our (your) Beoworld Gifts?
exactly ill order 6
Jandyt
- Joined on 04-01-2007
- Clitheroe, Lancashire, UK
- Posts 13,004
I always use damp kitchen roll followed by dry kitchen roll. I do remember the guy in Struer saying NO ALCOHOL! Andy T.
Page 1 of 1 (15 items)
