Just purchased a Beosound 2000/Century on E-bay, it comes with the wall mount and beo4 remote but no FM antenna.
Are these antennas still available from B&O? and if not what are my options?
Thanks in advance for all your help.
Roger
If you can fit the standard Rabbit Ear antenna, these are still available. If you need the combined carry handle and antenna, I think you be looking at Ebay.
Craig
Craig,
Thank you.
Is the rabbit ear the same as the one to the Beosystem 2500? I have only seen the one incorporated with the handle.
jason
