Latest post 01-12-2009 5:40 PM by Jandyt. 4 replies.
Page 1 of 1 (5 items)
  • 01-12-2009 10:18 AM
    mmc20 f cartridge, will mmc20 e fit as well?
    Currently, the cartridge I use is a MMC20 F. I can get a MMC20 E, but not sure if it will fit.
    Can anyone confirm if it will work?
    Cheers
    SS
  • 01-12-2009 10:30 AM In reply to
    Re: mmc20 f cartridge, will mmc20 e fit as well?
    Yes it will, you can use all MMC 10 or 20 cartridges!
     Ernie
  • 01-12-2009 10:43 AM In reply to
    Excellent!!
    Just wanted to make sure as these things are Veeeeeeerry expensive!
    Thanks for your help!
  • 01-12-2009 4:47 PM In reply to
    Not come across an f! Do you mean MMC20S?  I would suggest getting a Soundsmith one anyway - will be far better sounding.
  • 01-12-2009 5:40 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    If I remember correctly, the 'E' just refers to the diamond, not the cartridge. 'E' meaning Eliptical.
    I think many MMC20s from that time period will be 'F' by now! Laughing  Best go for a Soundsmith.
    Poor me, never win owt!
