1st March February 2012
Latest post 01-14-2009 4:51 AM by david707. 4 replies.
01-12-2009 5:19 AM
dko7113
![](/utility/anonymous.gif)
![Top 500 Contributor Top 500 Contributor](/Themes/beotheme1/images/rankicons/rankTop500.gif)
![Male Male](/Themes/beotheme1/images/rankicons/GenderMale.gif)
- Joined on 09-04-2008
- Copenhagen, Denmark
- Posts 104
![Gold Member](/Themes/beotheme1/images/roleicons/d27431af-8474-494c-aeb0-d1cede4cb008.gif)
MasterLink / Link room question
I have tried a similar question earlier with no response…
In my living room I have a BeoSound3200, and in my bedroom a MX4002. The two pieces are connected via MasterLink together with a BeoPort. I use the MX4002 as a normal TV and as a Link room speaker.
In my living room I can access the following audio sources: CD, Radio, A.MEM. A.AUX, N.RADIO and N.MUSIC using Beo4.
In my bedroom I can access the same audio sources except A.AUX using Beo4.
My question is why I am not able to access A.AUX from my bedroom? If I use the BeoPlayer from the PC connected to BeoPort, I do not have the problem. Is it because of some kind of limitation in the MasterLink system using Beo4?
If I choose for example Radio on the Beo4 in the bedroom, I got access to listen to radio. If I then walk to the living room and choose Radio on the Beo4, I got access to listen to radio in the living room too. Then I choose A.AUX on the remote in the living room, and the sources change in both living room and bedroom. This is the workaround I use, when I want to listen to A.AUX in the bedroom.
Has anyone experienced same problem?
Regards, Erik
My Beo: BeoCom 6000, BeoCom 2500, BeoCom 1401, BeoLine, BeoVision LX6000, BeoVision LX2500, BeoVision MS6000, BeoVision MX4002, BeoVision MX1500, DVD1, BeoSound 3200, BeoSound 1, BeoLab 4000, BeoGram 4500, BeoPort, BeoPlayer, 3x Beo 4, 2x BeoLink 1000, V Terminal, Form 2, Light Control 2, BeoTime
PhilLondon
![Top 25 Contributor Top 25 Contributor](/Themes/beotheme1/images/rankicons/rankTop25.gif)
- Joined on 04-16-2007
- London
- Posts 2,545
![Founder](/Themes/beotheme1/images/roleicons/6f51347a-6d4c-4ff4-9d2e-4e3705076d55.gif)
Re: MasterLink / Link room question
I think this is due to a bug in the firmware of the MX. I think I read that somewhere on the forum. Have you tried calling LINK A-AUX with the Beo4 instead of A.AUX?
david707
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.27.22/avatar.jpg)
![Top 200 Contributor Top 200 Contributor](/Themes/beotheme1/images/rankicons/rankTop200.gif)
- Joined on 04-20-2007
- Posts 295
![Silver Member](/Themes/beotheme1/images/roleicons/3cca3820-1e81-47d8-9399-96612b7eabf0.gif)
I have the same problem with my MCL2AV. I cannot select A.AUX from this link. The only way to do it is from the central room. I can then monitor A.AUX on the (LX) TV. I can select all other audio sources except A.AUX. Using link> A.AUX does not work. I can however select A.AUX from both my MCL2A's. David
dko7113
- Posts 104
Hello Phil and David,
thank you for replying to my post.
LINK A.AUX doesn't work here either.
Anyway it is nice knowing I am not the only one having this kind of problem.
Regards,
Erik
david707
- Posts 295
No one has the answer to this one Erik. Please let us know if you find a solution! Regards David
Page 1 of 1 (5 items)
