Latest post 01-12-2009 4:23 PM by beoguy. 2 replies.
Page 1 of 1 (3 items)
  • 01-11-2009 7:43 PM
    Penta amp hummmmm...
    I bought a couple of penta amps (bottom only).  The power cords were cut and they were sold to me AS IS.  So I took a chance.
    I quickly taped up a power cord from the little pigtail that was left.  Hooked up the radio to the amp and then out to a speaker.
     Surprize!  It works!  I have another set in the living room (with the penta speakers also).  There is, however, a slight hum.  I turned the plug around to see if that was it.  Nope.  I switched the speaker + and - around.  Nope.
     Could it be that I just need to properly attach a new powercord?  Any advice, ideas?
    Thanks!
    Guy
  • 01-12-2009 11:56 AM In reply to
    • PL212
    • Top 200 Contributor
    • Joined on 02-14-2007
    • Moderator - Seattle
    • Posts 318
    Re: Penta amp hummmmm...
    Do you know the TYPE number printed on the bottom? You may be able to find some hints here: http://forum.beoworld.org/forums/thread/165467.aspx.
  • 01-12-2009 4:23 PM In reply to
    The amps are penta one's.  6603 I think?  I'm going to try the other amp tonight.  The hum does not hum at the amp, just the speaker.
    Guy
