Latest post 08-27-2007 4:20 PM by tobyfish. 1 replies.
Page 1 of 1 (2 items)
  • 05-22-2007 7:15 PM
    Beovision 7 -32 inch PCM problem possible solution
    Fellow members,
                            I have just been posted this from the B & O website by a chap called Herrn.  I will contact my dealer tomorrow and see if it is the way forward.  Here is the reply i got from him>>>>>>>>>
    Herrn Dirk Henkel
    Posted 19/5/2007 4:43 PM (#15964 - in reply to #15524)
    Subject: Re: Beovision 7: Having problems with Digital Audio? Then read this ...
    Quote Reply Alert
    Hi Mr. Carl, PCM calls "Pulse Code Modulation" or LPCM for "Linear Pulse Code Modulation". The Systems NTSC and/or PAL absolutely needed the PCM (2 channels). A new SW, I mean "Software (7.5)" is now available for the BV 7 to solve this problem Nr. 8 ! Your Dealer can it be update via PUC (or STB)
    Kind regards, Dirk
    lets all Hope this solves the porblem guys.
    Regards
    Carl Sheerman
    Carl Sheerman
  • 08-27-2007 4:20 PM In reply to
    Re: Beovision 7 -32 inch PCM problem possible solution
    Hi Carl,
    Does a software update resolve the problem?
    Best,
    Toby
