Latest post 01-12-2009 1:21 PM by Fil. 4 replies.
Page 1 of 1 (5 items)
  • 01-11-2009 9:34 AM
    • Fil
    • Top 500 Contributor
    • Joined on 04-17-2007
    • Posts 90
    A8 Headphones & BS7000
    Hi, and Happy new year to everyone!
    Got a pair of A8 headphones for xmas for my ipod.......fantastic!!
    Tried the A8's with my BS7000.
    I connect them and the sound keeps coming from the speakers (penta 3's) and nothing from the earphones.
    Can anyone help please?
    I'm sure it'll be something simple
    Thanks in anticipation
    Fil
  • 01-11-2009 10:21 AM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: A8 Headphones & BS7000
    How are the Pentas connected?
     Weekly top artists:
  • 01-11-2009 11:18 AM In reply to
    • Fil
    • Posts 90
    amongst the jumble of wires it looks as if they're connected to my Avant RF32 dvd........ M linked to the BS7000
    without taking them all out of the sock that's the best i can tell you for the mo
    Fil
  • 01-11-2009 1:45 PM In reply to
    • Alex
    • Posts 2,990
    You would need to connect the headphones to the Avant's headphones output, not the Beosystem 7000's. The headphones connection on each device will disable the device's own PowerLink outputs, not the PowerLink (speaker) outputs on other devices.
     Weekly top artists:
  • 01-12-2009 1:21 PM In reply to
    • Fil
    • Posts 90
    Hi Alex.
    Thanks for your swift reply.
    However, i tried your method and the sound still coming through the speakers.
    On further investigation it appears that one of the speakers is connected to the BS7000 ! i have Bl4000 as rears.
    But due to the jumble i cant see which one's which!
    Thanks again
    Fil
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
