Latest post 01-10-2009 2:24 PM by joeyboygolf. 2 replies.
Page 1 of 1 (3 items)
  • 01-10-2009 1:55 PM
    • Keyz
    • Not Ranked
    • Joined on 01-10-2009
    • Posts 1
    Help please Beosound 2300 Problem.
    Hello people  I wonder if someone could help me with a problem with my 12 year old Beosound 2300.
    Its never liked cdr's but now refuses to play normal cd's everythings fine with the machine but it wont read the cd , wont start to spin
    or anything. Radio works fine doors slide as they should.
    Any help would be much apprceciated
  • 01-10-2009 2:05 PM In reply to
    • arned
    • Top 500 Contributor
    • Joined on 04-24-2007
    • Denmark
    • Posts 97
    Re: Help please Beosound 2300 Problem.
    I had the same problem with my Beosound 3000 when it was about 2½ years old. The only way was to put a new CD-drive + mechanisme into the Beosound - and it did cost about the same as a complet plastic stereo-set in the supermarket.
    But after the repair the Beosound plays perfect - again.
    I think the Beosound 2300 has a different CD-drive as the 3000/3200.
  • 01-10-2009 2:24 PM In reply to
    Try cleaning the laser lens with a cotton bud damped in isopropanol. If that fail to fix it then you will probably need to replace the CD mechanism.
    Regards Graham
