Latest post 01-11-2009 2:14 PM by tournedos. 3 replies.
Page 1 of 1 (4 items)
  • 01-10-2009 8:51 AM
    • poulhs
    • Not Ranked
    • Joined on 01-10-2009
    • Posts 2
    Q: picoFarad: Beogram 5651 w/ MMC5 pick-up connected to a TerraTec iVinyl PhonePreAmp
    My record-player  Beogram 5651 w/MMC5 pick-up is connected to a TerraTec iVinyl PhonePreAmp .
    It has a setting for input capacity ("adjustable in three stages (100 pF, 250 pF and 430 pF") - and I have absolutly NO CLUE to proper settings...
    Their manual says: "Input-range selector switch Please refer to the technical documentation of your phono pickup system for the rec-ommended input capacity range for the preamplifier. Then set this selector switch to a value that best matches this range."
     Anyone who can help me?
  • 01-10-2009 9:14 AM In reply to
    Re: Q: picoFarad: Beogram 5651 w/ MMC5 pick-up connected to a TerraTec iVinyl PhonePreAmp
    430pF should be the right level. I have been searching for one of my spec sheets but have only found my SoundSmith one so far!! But all B&O cartridges have the same requirements!
    Take it all back! Just found my MMC20CL box with data sheet and it suggests 220pF!
  • 01-11-2009 1:55 PM In reply to
    • poulhs
    • Not Ranked
    • Posts 2
    A: picoFarad: Beogram 5651 w/ MMC5 pick-up connected to a TerraTec iVinyl PhonePreAmp
    Thanks Peter!
    By a coincident, I also found the spec for the MMC 5 R pick-up today, and it says: Capacity <= 400 pF for all MMC {5,4,3,2} R pick-ups.
    I assume that 250pF is less than 400pF :-)
    Anyone got  an idea of what's the difference in the sound?
     regards
    Poul
  • 01-11-2009 2:14 PM In reply to
    Re: A: picoFarad: Beogram 5651 w/ MMC5 pick-up connected to a TerraTec iVinyl PhonePreAmp
    poulhs:
    Not me, but it's quite safe to experiment, and simply use the setting that sounds the best for you. I would expect the load capacitance to mainly affect the higher frequencies, with 400 pF and above sounding a bit dull.
    -mika
