Latest post 02-10-2009 3:23 AM by waz1958. 5 replies.
Page 1 of 1 (6 items)
  • 01-09-2009 11:56 PM
    Ouverture
    I've just bought an Ouverture and would like to space the speakers a little further apart to create a wider soundstage.
    To do so, I need a 3 metre Powerlink (or 5pin male-to-male DIN) cable, and a similar length power lead between to the two speakers. Does anyone have a thought about where I might get these?
     thanks
  • 01-10-2009 4:15 AM In reply to
    Re: Ouverture
    Try your local B&O dealer
  • 01-10-2009 8:54 AM In reply to
    Re: Ouverture
    Or Lifestyle who will probably be cheaper. There are a number of B&O re-sellers and some of the more established ones have cables available to order Sounds heavenly are another source.
    I take it you are using Beolab 2500 speakers. I would strongly recommend thinking about upgrading to a pair of Beolab 4000s which are not a lot bigger and will change the quality of your sound massively.
  • 01-10-2009 9:11 AM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    Re: Ouverture
    Peter :
    They also look a lot better if you are going to space them out further.
    CraigSmile
  • 01-10-2009 9:45 AM In reply to
    • Dave
    • Top 50 Contributor
    • Joined on 04-17-2007
    • Brisbane, Australia
    • Posts 2,328
    Re: Ouverture
    1,000 times better Wink
  • 02-10-2009 3:23 AM In reply to
    Re: Ouverture
    Thanks for the Beolab 4000 tip. I've obtained some leads from my local B&O store and now have a wider more satisfactory sound...but now I'm keen to take it further. Thanks again.
