Latest post 01-09-2009 3:36 PM by jk1002. 2 replies.
Page 1 of 1 (3 items)
  • 01-09-2009 12:21 PM
    • BeoNut1
    • Top 500 Contributor
    • Joined on 08-19-2007
    • Mobile, AL (USA)
    • Posts 226
    News on an updated BV 8 LCD panel?
    I need to purchase another 32" BV8 (this one for my office); any news on when B&O might be considering putting a newer LCD panel (with higher flicker rate / LED backlight / etc.) in this TV?
    TIA,
    Mark
    Mark D
  • 01-09-2009 2:34 PM In reply to
    • VANTAGE
    • Not Ranked
    • Joined on 09-02-2007
    • Paris, France
    • Posts 22
    Re: News on an updated BV 8 LCD panel?
    Allow me to add a question on the same topic (BV8): does anybody know if you will be able to add a DSS module to the 40" version of BV8 (apparently introduced during the Spring of 2009?)
    Many thanks.
    Klaus
  • 01-09-2009 3:36 PM In reply to
    The BV8 with 40" is supposed to get surround, might be optional though.
    For the updated LCD panel for the US, nothing is rumored plus I would think they would sell off the older ones first. They did the same with the BC2 when it got a minor update.
    If you are after a 2nd BV8, there is supposed to be an update to the european BV7 32" some time soon. I am hoping this one would get to the US then, but again nothing is rumored for us here so far. That might be interesting for you as well, I will certainly consider it myself.
    Cheers
    JK
    P.s. @Beonut, if you are still using your ATV, take a look at my boxee.tv posting in the US section.
