Hallo,
Wie weet er meer over BeoCom 5. Gaat deze voor de zomer komen? Zijn er foto's?
Zie hieronder een tekst uit een topic op het algemene forum over BeoCom 5:
Beocom 5 has an Hourglass shape, it does not look like the Bc 4 or Bc 6000. The table charger is small - half the handset size. The table speaker is round, in aluminium, about the size of a CD. Flat on top, round underneath, with a table stand in the style of the Beocenter 2. You activate the speaker by placing the handset on the speaker base. It is compatible with BC2 and BC6000 PSTN base. It is compatible with VoIP, has a colour screen, nice ringtones similar to the Beocom 2. Will be a bit more expensive than the BC6000.
