Latest post 01-08-2009 12:25 PM by johnheartfield. 4 replies.
Page 1 of 1 (5 items)
  • 01-08-2009 12:04 PM
    BS9000 problem
    9000 (wall hung vertically) happily playing through an Avant in a link room. Suddenly stops playing. Go into other room and see 9000 has switched itself off with clamper still in position 2 - red light still on at position 2. Switch it back on and it lights up, says CD1 and immediately switches off again - still with clamper unmoved at position 2 red light still on at 2.
     Tried the computer solution - switch everything off at the mains, unplug, wait a while, plug back in, switch on - still same problem as before.
    Any suggestions if only to get clamper back to position 1?
    Regards
    John
  • 01-08-2009 12:13 PM In reply to
    Re: BS9000 problem
    Mechanical failure?
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 01-08-2009 12:18 PM In reply to
    Re: BS9000 problem
    Could be.
    Just pressed button to open door - opened about half way, red light flashed three times and door shut again by itself. Not looking good.
    John
  • 01-08-2009 12:22 PM In reply to
    Re: BS9000 problem
    Have you tried cleaning the "hand sensors"? There are sensors that are supposed to shut down the clamper motion, in case a hand is detected, a child safety measure. Those sensors need to be cleaned if they've dusted up.
  • 01-08-2009 12:25 PM In reply to
    Re: BS9000 problem
    Had problem with sensors before as it is vertically hung so I am careful about keeping it clean. Just cleaned them again but nothing has changed.
     John
