Hi~~
I'm assuming the BS3 works the same was as the Avant.  Plug in the headphones, then on the Beo4 remote, press right in the middle of the volume up/volume down button on the lower end of the remote.  This will turn off sound to your speakers and only send sound thru your headphones.  See if that does the trick~~
