Yes it is a wreck, but it´s on my table right now, and if it´s broken, fix it :-). And if i can use it in my livingroom, noone will see it´s broken when the cover is closed. But, if someone, like in this case, says it´s broken and just to throw away, i really must repair it just because...
Anyway, i found out that it´s probably the bearing in the bottom of the motor that is worn out, when i lift the axle it´s quiet... Any ugly tricks to fix it?
It wasn´t the bearing, it´s a piece of plastic inside the motor that has got loosened. I will try to glue it and post a picture of it here.
//Erik
