A few months ago, I purchased a beogram 8000 with a beomaster 8000 and beovox 150 speakers for the high sum of $150. It came with a MMC20 CL cartridge. I then purchased a beocord 8000. I have questions on each piece, hope i can get some answers. BTW, I already took the beomaster apart out of curiosity, its such a wonderfully put together piece of equipment. I plan on re-capping every unit as well.
-Beomaster
I tried hooking it up to some speakers I had with a tv input to the Tape In. I got very LOUD sound coming from the speakers, and immediaetly switched the speakers off. This was with the volume all the way down. On tuner, the speakers played fine. Some of the digits on the display are missing segments as well.
I am assuming a cold solder joint for the display? Does anybody have any advice on re-capping? A list of components maybe? I have the service manual, but is it accurate? How are electrolytics marked? Is tape in capable of accepting a regular input?
-Beogram
This one seems to work fine, except it drops the stylus. Should it lower it slowly? I am worried that the stylus will break if its dropping the cartridge.The cartridge looks like its very tip is broken. It skips, but sound does come out of both channels. Can this guy be re-tipped? I have a cartridge coming in from soundsmith. But im afraid to put it in till i know this tonearm is working properly.
Beocord
I cant test it as it needs belts, where can I get them, and how does this unit come apart to service?
Beovox
Where can i get the foam for these guys? I would rather send the drivers to someone as they are of tight tolerance, but a foam source would get me on the right path. Are these guys old enough to warrant a re-cap?
Any and all help would be greatly appreciated. I already LOVE this beogram and want a 4000 someday, I really am excited to get it all running again.
http://www.flickr.com/photos/14683866@N03/2994445660/sizes/l/in/set-72157608576196246/
