Latest post 01-07-2009 2:55 PM by Dillen. 3 replies.
Page 1 of 1 (4 items)
  • 01-06-2009 1:09 PM
    beogram TX 2 turntable drags LP on deck after tone arm crosses 1/3 of the LP - help
    Is there an easy fix for this problem?  Everything sounds great until the tone arm crosses 1/3 of the album then the outside edge of album starts dragging on the top of the deck which slows the deck down.
    Thanks for any help.
  • 01-06-2009 3:08 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: beogram TX 2 turntable drags LP on deck after tone arm crosses 1/3 of the LP - help
    Welcome to Beoworld and thanks for signing up as a silver member, your support is greatly appreciated !  Yes -  thumbs up
    There are three adjustment screws with leaf springs for the platter height.
    I suggest you adjust them and set the platter apprx 1mm above the surrounding aluminum surface.
    They can be accessed by lifting off the platter. The platter lifts straight up but will often bind drastically.
    For you, being a silver member, the service manual is available for download
    from the main website/products section.
  • 01-07-2009 10:11 AM In reply to
    Thanks for your help.  I only had to adjust one of the screws.  No more drag!
    I really appreciate the help coming so fast!
  • 01-07-2009 2:55 PM In reply to
    • Dillen
    • Posts 5,008
    You're welcome.
    Don't be a stranger now. Yes -  thumbs up
