Latest post 11-10-2009 11:06 AM by frank2u. 8 replies.
Page 1 of 1 (9 items)
  • 01-06-2009 4:51 AM
    Beolink PC Office and Windows XP
    Is there a software version that willl make the Beolink PC Office to work on Windows XP?
  • 01-12-2009 10:20 AM In reply to
    • bdm01
    • Not Ranked
    • Joined on 01-07-2008
    • Posts 36
    • Gold Member
    Re: Beolink PC Office and Windows XP
    hi,
    Should be no problem I have 2 PC Office units (now called Beoport) working and both are on XP machines.
    Make sure you have downloaded the latest Beoport software from the B&O website and go through the installation procedure.
    A tip would be to make sure you do not make the USB connection until you are told to.
    If you need anymore help then post a reply or send me a PM.
    Best regards
    Richard
  • 01-29-2009 4:40 AM In reply to
    Hi Richard
    I don't have the USB version, but the old RS232.
    Struer told me, that it can't work under XP.
    Regards
    Frank
  • 01-29-2009 1:36 PM In reply to
    • bdm01
    • Not Ranked
    • Posts 36
    • Gold Member
    Hi Frank,
    both my units are USB, Your's must be an early unit, the only thing I can think of to try would be to connect it to your PC using a serial (rs232) to USB adapter and just hope it works.
    It may not work but at least the adapter only costs a few pounds / Euros
    Regards
    Richard
  • 02-13-2009 1:07 PM In reply to
    Hello Frank,
    any progress on your efforts?
    I am thinking of buying a unit (BeoLink PC Office) if it will work with XP.
    I like the possibility to hear music from the main room (Active Kit) without having to switch on the PC Smile
    Frank
  • 02-13-2009 1:10 PM In reply to
    This is a very old device and is no longer supported. I would be interested to hear if it does work with XP simply so we can update the site information.
  • 02-26-2009 3:01 AM In reply to
    I tried to install the PC Office on Windows XP. But before the installation begins there is a check if all conditions are fulfilled. In compatibility mode the operating system is accepted but it hangs in the check of the serial ports. It says that a special file is missing. I don't know now the exact file name. It is a VXD file. But the file is available in the installation directory. I had no success to get over this barrier.
    Frank
  • 11-09-2009 3:35 AM In reply to
    Hi.
    Is your problem solved?
    I have  the same problem with beolink ofice and WinXP.
    Marijo.
  • 11-10-2009 11:06 AM In reply to
    Hello,
    no it is not working. I gave it back.
    Frank
