Latest post 01-09-2009 5:29 PM by Xseries. 4 replies.
Page 1 of 1 (5 items)
  • 01-05-2009 3:12 PM
    • robbeo
    • Not Ranked
    • Joined on 01-02-2009
    • Posts 2
    Use ML/MCL Converter as stand-alone amplifier for passive speakers
    Hi all
    I have a ML/MCL Converter and an IR eye which I do not currently use. Now I am looking for a solution to use the converter as amplifier for some passive speakers. This is meant to be a stand alone solution - no link to any B&O system required. Unfortunately there is no way to switch the converter on
    Is there a way to connect an iPod to the converter by using an adaptor? How can I use the setup without the need to knock something together?
    Does anyone have an idea?
    Rob
  • 01-06-2009 4:49 PM In reply to
    • Xseries
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Hampshire
    • Posts 433
    Re: Use ML/MCL Converter as stand-alone amplifier for passive speakers
    You can try switching it on using a Beo4 or Beolink with the following commands "Menu  0  3  Play" - but that is a test mode so I do not know if it will achieve what you want.  With the above it does not need to be connected to an ML driver.  STOP sends it back to standby....
    Brian
    PS
    I would be interested in any other replies too!
  • 01-08-2009 4:39 PM In reply to
    • Xseries
    • Hampshire
    • Posts 433
    Have you had a chance to try the suggestion out?
    I have tried with an eye - but  I am not sure if the eye is working!  I am going to dig out another eye and try again at the weekend.
    Brian
  • 01-09-2009 12:30 AM In reply to
    • Mico
    • Top 500 Contributor
    • Joined on 05-06-2007
    • Finland
    • Posts 136
    You need a MCL 2AV to attach local sources to the amplifier. The Transceiver unit has to be connected to the link unit. I recall that my previous setup (BG 6500 and BC 6500 in a link room) worked locally even when the master was not present. You did not mention if you have the square or hockey puck type Transceiver.
  • 01-09-2009 5:29 PM In reply to
    • Xseries
    • Hampshire
    • Posts 433
    Does the MCL2AV work with the later ML/MCL converter (hockey puck eye marries up via 7 pin din) or only the MCL 2P (older rectangular transceiver - bare cable)?
    Brian
