Latest post 01-07-2009 1:27 PM by AC30. 7 replies.
Page 1 of 1 (8 items)
  • 01-05-2009 6:10 AM
    • AC30
    • Not Ranked
    • Joined on 01-05-2009
    • Posts 4
    Confused [*-)] ??? Trouble with LX2800 and DVD feeds only sometimes working where video works fine...???
    I've just got myself a superb, white, LX2800 in mint condition.   Two loving owners.   Blimey, what a beauty...
    Anyway, all is very well indeed apart from the fact that it seems to disagree with both of my DVD players.   The DVD signal seems to be getting through to the TV but the sound stops and the picture has horizontal sub flickering throughout the screen.
    This has not gone down well with my kids of 3 and 1, who, if they don't get their dose of Oliver Postage's finest works on a regular basis make their views very clear.
    The old VHS works fine as does the TV itself on a SKY dish signal through ye olde scart lead.
    But only some DVSDs works through either my Toshiba DVD player or the super cheap (but does the job) Alba one.   And the funny thing is that it is different DVDs that work with each.   It is of course possible that both DVD players are on the blink at the same time, highly unlikely though - both of them were consistent performers with our old TV.
    Has anyone else had the same problem?   Any technical advice out there?
    Cheers
  • 01-05-2009 6:45 AM In reply to
    • dko7113
    • Top 500 Contributor
    • Joined on 09-04-2008
    • Copenhagen, Denmark
    • Posts 104
    • Gold Member
    Re: ??? Trouble with LX2800 and DVD feeds only sometimes working where video works fine...???
    Strange...
    I have the smaller model LX2500. I have had several different DVD players connected to it without any problems.
    I have connected them to the LX through a SCART cable, and then I choose V.AUX2 on the remote.
    Regards,
    Erik
    My Beo: BeoCom 6000, BeoCom 2500, BeoCom 1401, BeoLine, BeoVision LX6000, BeoVision LX2500, BeoVision MS6000, BeoVision MX4002, BeoVision MX1500, DVD1, BeoSound 3200, BeoSound 1, BeoLab 4000, BeoGram 4500, BeoPort, BeoPlayer, 3x Beo 4, 2x BeoLink 1000, V Terminal, Form 2, Light Control 2, BeoTime
  • 01-05-2009 7:03 AM In reply to
    yes, i could imagine that the DVD player uses RGB and FBAS at the same time. MY old MX5000 does not like it either... i had to cut the RGB lines and Blanking (pins 7+11+15+16), so it uses only FBAS.
    Try it on a cheap Scart cable...
  • 01-05-2009 12:39 PM In reply to
    • AC30
    • Not Ranked
    • Posts 4
    Very helpful Martin
    Please excuse my ignorance but what are RGB and FBAS?    And how would i cut lines to produce just FBAS, would it be literally attacking the scart lead pins?   I could understand that from a 5 pin DIN lead point of view, maybe scart work in a similar way i.e. pins are allocated spedific feeds etc...    Or are there certain leads withint the scart i should cut?
    Many thanks!
  • 01-05-2009 12:40 PM In reply to
    • AC30
    • Not Ranked
    • Posts 4
    Thanks Eric, I'll try that and see what happens.   it sounds like a solution is on it's way one way or another.   cheers
  • 01-05-2009 12:45 PM In reply to
    Look here....
    It's from a VX5000, but dont care about...
    http://img511.imageshack.us/my.php?image=belegungvl0.png
  • 01-05-2009 2:23 PM In reply to
    • Craig
    • Top 10 Contributor
    • Joined on 03-29-2007
    • Costa Del St Evenage
    • Posts 4,855
    AC30:
    Cheers
    Had this problem myself with an MX6000. Mine was a very simple fix, I swapped the Scart lead round the other way. Now I have no idea why this should fix the problem but it did. Got to be worth trying.Wink
    CraigSmile
  • 01-07-2009 1:27 PM In reply to
    • AC30
    • Not Ranked
    • Posts 4
    Nice touch Craig - I'll give it a try!   Thanks
