I'm new to the Beoworld forum but I purchased my first B & O turntable, (3000 I think), as a starry eyed teenager in the early 70's. Seems like it was around 300.00 and I had to throw a lot of newspapers to pay for it. Now I have an older Beogram 8002 which I rescued from a pawn shop around 1990. It has been closeted for several years after I got into CD's heavy. Maybe 10 years ago I had it out and transfered a couple of albums onto CD and it worked fine. Now I have brought it back out and would like to return it to it's proper place on the componenet shelf. However, upon trying to play, I discovered......it won't.
The drive coils hum and the platter tries to spin backward momentarily as the tonearm also hums slightly and seems to try to move. While this is happening the LEDs'  flicker the 33 numbers shortly before everything stops. Also I notice the red arrow on the tonearm flickering for a moment. All of this happens in maybe 1 1/2 to 2 seconds. Trying the turn, play or tonearm transport buttons all end with this same response. If I unplug the unit and then plug back in I get the same response. I have tried with and without a record on the platter and get the same result.  My soldering skills are decent, but my troubleshooting of electronic components not so much, although I do have a copy of a repair manual.
Any help in the troubleshooting and/or locating parts would be much appreciated.
Mike
