Latest post 01-05-2009 4:22 PM by Carl Sheerman. 7 replies.
Page 1 of 1 (8 items)
  • 01-04-2009 6:35 PM
    BV 7, 40 inch and Beolab 7.1
    Rather than buy a new center speaker for my soon to be delivered BV 7 40 inch i am keeping my 7.1 speaker from my 32 inch BV 7.  On the selection process for the center speaker during setup can you select a 7.1 rather than a 7.2 or the rest of the beolab range.  Thank you.
    Carl Sheerman
  • 01-04-2009 6:42 PM In reply to
    • Alex
    • Top 25 Contributor
    • Joined on 04-16-2007
    • Bath & Cardiff, UK
    • Posts 2,990
    Re: BV 7, 40 inch and Beolab 7.1
    I can't say either way, but it shouldn't matter from a sonic point of view as the two are pretty similar. I can't say I would want a 7.1 mounted underneath a 7-40 visually though.
     Weekly top artists:
  • 01-04-2009 6:51 PM In reply to
    The main reason for the 7.1 was money.  I had enough for the tv and not a new center speaker but visually i have seen it on the STB brackets webiste and i think it looks ok.  Tried to put the picture on the site but not sure how to attach a picture to posts.  Thank you for your advice.
    Carl Sheerman
  • 01-04-2009 7:27 PM In reply to
    7-2. That's what I have got and its superb. That's all you need to know. Good night...
  • 01-04-2009 7:29 PM In reply to
    Happy new year...
  • 01-04-2009 10:49 PM In reply to
    Right. The speakers are sonically the same, just spaced differently to accommodate different screen sizes.
    I personally would have taken your 7.1 on a trade to make sure you got the whole enchilada.
    There is scarcely anything in this world that some man cannot make a little worse and sell a little more cheaply. The person who buys on price alone is this man's lawful prey. - John Ruskin
  • 01-05-2009 6:09 AM In reply to
    I have a BV7 MK3 with a 7.1 mounted underneath, and it preforms equally to the 7.2 only difference is the size.
    Jon
  • 01-05-2009 4:22 PM In reply to
    Glad you agree i have not got the knack yet of putting a picture on this forum but when the tv is fitted i will endeavor to show to all.  The only place i have seen it is on the STB site.  I personally think is will look more uniform as i always thought that the speaker sticking out the sides looked slightly odd but still stunning.
    Thanks all for your views
    Carl Sheerman
