Latest post 05-22-2007 11:39 AM by Peter. 1 replies.
Page 1 of 1 (2 items)
  • 05-22-2007 10:36 AM
    Low volume from Beogram 5500
    I have a Beogram 5500 that is feeding into a B@0 6500 system, the volume has to be turned up all the way to hear the record play. Is a Beogram needed that has an internal RIAA amplifier or is there an adjustment somewhere?
  • 05-22-2007 11:39 AM In reply to
    Re: Low volume from Beogram 5500
    You have identified the problem correctly. The Beomaster 5500 has a RIAA built in, but the 6500 does not. Therefore the Beogram 5500 will not work properly - you may also have noticed that it doesn't respond to your remote! You need an external RIAA - interesting thread on how to make your own here!
