Latest post 01-02-2009 5:32 PM by tubbs. 2 replies.
Page 1 of 1 (3 items)
  • 01-02-2009 2:42 PM
    • tubbs
    • Not Ranked
    • Joined on 01-02-2009
    • Posts 2
    beosound 3000
    Hi , Happy new year !
     I just returned from hols, ( inlaws house sitting)
    before i went away, i turned off the system at the mains, (never had an issue with this before)
    When i came back i turned on as usual, waited for the pin code screen, and am instead greeted with the message "wait"
    this flashes up for a couple of seconds and goes off again, If i press load the tray opens as usual, but any other functions are greeted with "wait "
    any ideas?
     thanks in advance !
  • 01-02-2009 3:08 PM In reply to
    Re: beosound 3000
    I think you will have to leave it plugged in and wait for three hours. It should then request the PIN again. Once you are in and the system is working I would deactivate it and you won't have any more hassle!
    It won't stop anybody from nicking it, it just causes you grief.Angry
    Regards Graham
  • 01-02-2009 5:32 PM In reply to
    • tubbs
    • Not Ranked
    • Posts 2
    Re: beosound 3000
    yeh that was it, it seems it counts down the time 3 hours from when turned on, not from when the code was put in incorrectly . and subsequently turned off at teh mains
     ( thanks bro-in-law) Big Smile
    cheers
