As you have only justed purchased your Beo5 it may have the latest firmware loaded in it, so the first step is to determine which version of firmware you have loaded in your Beo5. To do this, on the Beo5 press hand HOLD the RED DOT button and press the centre button which will take you into the SETUP menu, now press INFO and read the "Software Version"
If the SOFTWARE VERSION reads 1.40a then you will need to use the Beo5 Configuration Tool version 2.2
If t reads 1.34a then it should work with your version 1.30 configuration tool and in this case we will need to research teh problem further.
