If the Playstation 3 is set as PC, it must be using the DVI port? If so, you won't get any of the normal Bang & Olufsen menus appearing on the screen.
A tech bod will need to explain why, but it won't appear on any source using DVI.
As for the factory settings, I'm certain they were all set at 40 out of the box.
